Clutch problem
Old Nov 14, 2004 | 04:19 AM
johnnyji's Avatar
Default Clutch problem
Hey all
My 92 cbr900rr has a bit of a shudder if you take off in first gear and let the clutch out relatively normally, with regualr revs. The only way to avoid it is to ride the clutch until the bike is moving relatively smoothly.
The interesting thing is that the bike is moving just fine when i'm slipping the clutch and there aren't any noises or anything, But when i fully let out the clutch that's when the shudder happens.
The sound resembles a bit the noise you would hear if you let out the clutch with very low revs (almost stalling the bike).
btw, there is no shudder (sometimes there is a little tiny bit of shudder) , if the bike is slowly moving in 1st when i let the clutch out.
Thanks for your help
Ivan
Old Nov 14, 2004 | 01:02 PM
Baldman's Avatar
Default RE: Clutch problem
Sounds like you have a warped plate or your discs have become glazed. How many miles do you have on the odometer? Are these actual engine miles, or is there a possibility the original odometer has been swapped?
Old Nov 14, 2004 | 01:53 PM
johnnyji's Avatar
I have around 18 000 miles on it. I think the bike is still with the factory clutch
Old Nov 14, 2004 | 09:01 PM
chainstretcher's Avatar
Admin Emeritus & MVN
ORIGINAL: johnnyji
I agree with Baldman. Change both the fibers and steels. Shuddering will go away. While in there, check condition of basket and springs. Change springs also if out of spec.
Old Nov 15, 2004 | 02:00 AM
johnnyji's Avatar
Thanks for the advice. I'll let you know what happens when i replace the disks.
mlrtime99
Oct 10, 2007 03:11 PM
smak_blaze
Mar 30, 2007 05:40 PM
lowrinlife
Jul 30, 2006 02:18 PM
lowrinlife
May 27, 2006 12:18 PM
lowrinlife
May 26, 2006 09:21 PM
