Clutch friction plate and steel plate thickness? Clutch spring free length?
Old Apr 27, 2006 | 02:18 AM
zeeexsixare's Avatar
Default Clutch friction plate and steel plate thickness? Clutch spring free length?
My F2's clutch has been slipping lately and I'm going to tear into it to hopefully find the problem or replace the plates. Does anybody know the minimum thickness that the friction plates and especially the steel plates can be? In addition, what is the range for the free length of the clutch springs? I have the Honda common and F2 manuals from online, but they don't say jack about any specific numbers. Or if you know that they give the numbers, could you tell me where in the manual it has that info?
On that note, has anyone here had better luck with Kevlar plates as opposed to the regular fiber ones?
Old Apr 28, 2006 | 12:07 AM
kustom98f3's Avatar
Default RE: Clutch friction plate and steel plate thickness? Clutch spring free length?
For 92 friction plate thickness std is 2.92mm - 3.08mm
service limit is 2.6mm
Spring free length is 48.9mm
service limit is 47.5
Hope that helps.
Old Apr 28, 2006 | 02:35 AM
Thanks so much! Do you happen to know the steel plate thickness numbers, too? Or will I be able to tell by looking at the thickness from the inner gear section to the part that interfaces with the friction pads?
Old Apr 29, 2006 | 04:29 PM
kustom98f3's Avatar
Not sure on the steels. I checked my haynes manual and it didn't mention anything about them. Sorry.
Ls1Mx5
Dec 26, 2014 07:15 PM
vangill
Mar 30, 2010 04:35 PM
pontyhufc
Jan 22, 2010 12:35 AM
mccannf3
Mar 26, 2008 12:24 PM
