Cluch Replaced/Won't Start Once Warm
Old Feb 3, 2008 | 07:38 PM
wynnefieldCBR's Avatar
Default Cluch Replaced/Won't Start Once Warm
I have a 2005 CBR 600RR. I just had the clutch replaced by the dealer and now the bike won't start once it warms up. It's like the battery is low. It cranks slow and then stops cranking. If I let it cool down for about 10 minutes it will start with no problem. I replaced the battery. Anyone have an idea on what could be wrong?
Old Feb 3, 2008 | 09:12 PM
pacemaker's Avatar
Default RE: Cluch Replaced/Won't Start Once Warm
Sounds to me like you have a charging problem, I can't see the clutch replacement being related, unless the mechanic really stuffed up! I suggest its just a coincidence & you should be looking at your regulator & so on to see wots wot. Once the bike is warmed up, it should start easily, If your starting it up & doing a few clicks, then I suspect the battery is drained when you go to restart.
Old Feb 3, 2008 | 09:21 PM
Tacoma25's Avatar
What about a starter issue? Sometimes they get week and you do not notice unless they are warm, and they will crank slow like the battery is dying...
ny rider
Jan 22, 2013 10:43 AM
Chillax (CHLX)
May 13, 2010 12:22 PM
wish1267
Apr 4, 2010 09:08 AM
JayBoCC2
Jun 23, 2009 10:23 PM
cmasonrun
Sep 1, 2008 04:08 PM
