clicking in gear only
Old Aug 10, 2009 | 08:40 PM
stensg's Avatar
Default clicking in gear only
i have a 90 cbr f1 i get a clicking noise when it is in gear and moving from the transmission any ideas what i should check?
Old Aug 10, 2009 | 10:46 PM
johnnyx's Avatar
Inspect your front sprocket for wear. Also, throw it up on a stand, and turn the rear wheel by hand, inspecting the chain for stiff links.
Old Aug 11, 2009 | 08:03 AM
Todd84's Avatar
Does it do it in any gear? Do what John said and if that is not the problem you may have gear problems. If it only does it in a certain gear you will have to replace that gear.
Old Aug 11, 2009 | 05:29 PM
stensg's Avatar
not sure if its every gear since i just bought the bike for $300 for a winter project. i have been scared of the trannny locking up on me. once i get done moving and get the carbs back on ill put it on a stand and go through the gears. in the mean time ill look the chain over was going to clean and lube it tonight anyway.
Old Aug 11, 2009 | 06:12 PM
justasquid's Avatar
In addition, while looking at the chain for stiff links, make sure the chain isnt adjusted too tight. It puts a bind on the output shaft bearing and can cause odd noises.
LocRider
Nov 30, 2010 11:10 PM
Chrisct713
Sep 21, 2010 02:29 PM
Vermino
Jun 23, 2009 02:50 PM
F4i Amber
Jul 7, 2008 02:33 AM
markheggie
May 11, 2008 09:41 AM
