Chain tightness question
Old May 6, 2008 | 11:44 AM
Munson's Avatar
Default Chain tightness question
I've heard it's common for a chain to have tight and loose spots, but mine is extreme.
If the tightest spot is like a guitar string, at the loosest point it has nearly three inches of slack I can loosen it enough to have slack at the tightest spot, but then the loose parts will really be loose.
Is this a serious problem? Is there anything I can do, or have some links gotten so stretched out that it's just time for a new chain?
Thanks.
Old May 6, 2008 | 12:40 PM
scattabrain's Avatar
Default RE: Chain tightness question
check the teeth on your sprockets too. You might have one thats bend or something. Either way if its your sprockets or your chain its time to replace the part thats broke if not both.
Old May 6, 2008 | 01:06 PM
Nauree's Avatar
You measure the free play at the TIGHTEST spot on the chain. Sounds like your chain needs to be replaced.
Old May 6, 2008 | 02:07 PM
MikeInCtown's Avatar
It makes no sense that the chain would be that tight in large spots and then have another part of the chain hanging slack.It seems as though the links are bound up causing the problem. You could try lubing the chain really good and spinning the wheel while up on a stand to see if you can get it to loosen, but most likely it will need to be replaced.
Old May 9, 2008 | 09:19 PM
mercurysunshine's Avatar
usually cahin slack is supposed to be anywhere from 1" 1/4 to 1" 3/8 depending on the bike 3 inches is way to much. replace chain asap unless you can pull your wheeel back some more
Old May 9, 2008 | 09:40 PM
dementedf3's Avatar
ORIGINAL: Munson
Thanks.
My RK chain is doing the same thing. Mine has maybe 5000 mi on it since i got it and the sprockets. I was told it was from the stress of clutching up second. It really sucks because i was not wanting to buy another chain
Old May 10, 2008 | 09:06 AM
Nauree's Avatar
ORIGINAL: dementedf3
ORIGINAL: Munson
Thanks.
Probably from lack of maintance on the chain. My RK has lasted 5000+ miles and I still dont even need to tighten the chain.
Old May 10, 2008 | 09:56 AM
KidCr3nshaw's Avatar
A chains slack is checked on the bottom run, halfway between the front and rear sprocket... jeez guys, I thought you were bikers...
It should be between 1 5/8" and 1 3/4" if I remember right. It's been a while and to be honest, I don't measure anymore.
You also should be checking the slack WITH YOU ON THE BIKE.
Sounds like what you've got, Munson, is a trashed chain. I'm guessing your rollers are shot which is why it feels tight in some places, loose in others and there isn't any consitency in it's tension. Combine that with stretched links and it's time to replace...
Old May 10, 2008 | 09:57 AM
RK sucks, BTW.
RobRz
Jan 31, 2011 06:41 PM
Zarflax
Nov 28, 2009 07:59 AM
Fairlane
May 23, 2009 11:14 PM
Perranomous
Apr 19, 2009 03:04 AM
fafar59
Sep 5, 2006 12:04 AM
