Question about Chain tightness!
Old Sep 2, 2006 | 06:20 PM
fafar59's Avatar
Default Question about Chain tightness!
Last week I cleaned up my chain and tight it, but I tight it too much. Chain free play is an inch right now. Is it harmful?? Do I need to adjust it again or not?
Thanks
Old Sep 2, 2006 | 07:51 PM
bobjoezx's Avatar
Default RE: Question about Chain tightness!
inch when your on or off the bike.. u need atleast a half an inch when your ON your bike.. heres the key.. if u can hear the cahin when u are on the bike and you push it back.. it's too tight.. if you can hear it when you ride it's too loose
Old Sep 2, 2006 | 09:21 PM
03954guy's Avatar
reading is fundamental it says right there on the side of your bike right on the chain guard 1.75 inches of free play thats what honda says and since they are the ones who produced this vehicle i do beleive that they might be correct
Old Sep 2, 2006 | 09:37 PM
bobjoezx's Avatar
very true.. very true
Old Sep 3, 2006 | 12:54 PM
fafar59's Avatar
Thank you very much gentlemen. I adjusted my chain at 1.8 free play, but it seems dry despite I lube it frequently with a chain lube (It is a Spray) is there anything better that you can recommend for lubing chain?
Thank you very much.
Old Sep 3, 2006 | 02:11 PM
bobjoezx's Avatar
a good chain lube is fine.. do not use WD 40
Old Sep 3, 2006 | 10:47 PM
NWA's Avatar
NWA
Make sure to lube it after you have ridden it so the chain is hot/warm, otherwise your wasting your spray.
Old Sep 4, 2006 | 04:59 AM
nikos's Avatar
I've heard good things and I have tried white lithium grease. I like it, but it makes a heck of a mess and it looks like you spooged all over your chain. Honda has a 'Chain Wax' that they sell that I also use. It works well, but I like switching between the two. The wax, you need to let setup for 10 minutes after you apply it and does not make much of a mess. Either way, again, don't waste your time putting your lube on a cold chain, ride around for 5-10 minutes to warm it up appropriately.
P.S. Generic lube from department stores kinda suck. It's messy and it doesn't seem to work as well IMO.
Old Sep 5, 2006 | 12:04 AM
03bladeRunneR's Avatar
honda says to run regular 80-90W gear oil on the chain, every 500 miles relube...
RobRz
Jan 31, 2011 06:41 PM
Zarflax
Nov 28, 2009 07:59 AM
Fairlane
May 23, 2009 11:14 PM
Perranomous
Apr 19, 2009 03:04 AM
Munson
May 10, 2008 09:57 AM
