Chain and rotors are rusty
Old Feb 8, 2006 | 01:17 PM
NavyRob's Avatar
Default Chain and rotors are rusty
I recently got my bike out of storage and my chain and rotors are rusty as hell. Riding the bike a bot took care of some of the rust on the rotors but im worried about the chain too. Any ideas?
Old Feb 8, 2006 | 04:41 PM
rubberband man's Avatar
Default RE: Chain and rotors are rusty
I would asy it depends on how rusty it is. I would get some chain cleaner and see if you can get it off. If it is really bad might just wanna get a new chain....
Old Feb 8, 2006 | 07:03 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Get the back end up and loosen the chain adjusters all the way. Clean the chain with kerosene or whatever floats your boat. Spin it around and see if you have any kinking tendencies going on. If it wants to kink up or if the rust leaves pits then change the chain. If you ever have to store it again for an extended time there's some stuff you can buy to spray on metal surfaces to keep it from rusting.
The rotors are o.k. -- rotors just rust ... that's what they do.
Old Feb 8, 2006 | 09:29 PM
NavyRob's Avatar
Well I went to town with some steel wool and got a lot of the rust off the chain. Although there are no kinking tendencies, the rust areas are spotted black. I lubed the chain and the bike runs fine...not sure how much of a pain it is to change the chain but I may end up doing that regardless. Even worse is how many bolts and nuts, especially around the brakes, corroded. Even after the steel wool theres a few that simply need to be replaced. Its extremely irritating because I like to keep my bike looking new at all times.
Old Feb 9, 2006 | 08:10 AM
Anubis's Avatar
Careful With that Steel Wool, it leaves bits everywhere don`t wont them clogging your chain up, Acf-50 is good to prevent rust......
Obviously you can`t use it on the rotors.
Description: This anti-corrosion formula contains no wax, resin, silicon, or teflon to gum up mechanisms or trap moisture.
Old Feb 9, 2006 | 09:46 AM
Lubricates and penetrates mechanisms, eh? Sounds kinda kinky
Phil314
Jul 5, 2015 04:59 AM
Daniel.Hennessy@va.g
May 29, 2008 11:40 AM
Holeshot
Dec 30, 2007 11:10 PM
BoRkA
Oct 20, 2007 03:01 PM
JZHALES
Mar 16, 2007 01:19 AM
