chain "new zone"
Old Oct 20, 2010 | 12:35 AM
fairladylover's Avatar
Default chain "new zone"
so i bought this kit, for an 03 cbrf4i
RK CHAIN/SPROCKET KIT 525 XSO HONDA CBR600F4I 01-06
and i put it on and it was barely in the new zone. the new zone has a bigger area than the blue and red zone. but why did this kit not get me farther to the right on the new zone.
Old Oct 20, 2010 | 12:59 AM
OutlawF4's Avatar
How many links was it?? Need atleast 115-120. Could have been 108 links?? It will stretch in the next few hundred miles probably.
Old Oct 20, 2010 | 01:45 AM
it was 112 link chain.
i was under the impression that the more a chain stretches, the more u tighten, the more u move toward replace zone, away from blue and new zone.
but with this new chain i was barely in the new zone, almost creeping into the blue area.
Old Oct 20, 2010 | 02:01 AM
OutlawF4's Avatar
I just put a 120 link chain on mine. Had to take out 5 links and its way into the new area. If its too long, you have to take out a link or two then with a chain tool.
Old Oct 20, 2010 | 09:08 PM
gotcbr's Avatar
Using stock gearing, install at 108 links.
Old Oct 20, 2010 | 11:13 PM
i took the master link off today to see if i would be able to take out some links. it isnt possible.
the f4i manual calls for 108 links and thats how many i counted, not 112 as the kit stated.
this is where the chain sits
it just seems too far along to the left for a chain w 2000 miles
Old Oct 20, 2010 | 11:27 PM
OutlawF4's Avatar
That sticker is in the wrong spot. Should be more toward the front of the bike, maybe 3/16th of an inch.
Old Oct 21, 2010 | 12:08 AM
gotcbr's Avatar
Ignore the sticker for the time being.
108 links = factory spec for factory gearing, which for your F4i is 16/46.
Do you know if your sprockets are stock sized or not? If yes, the 108 link chain is correct.
Once chain is installed, & you turn the adjusters to take up slack, you should not be quite to the second notch on top of the adjuster at the back of the swingarm (this assumes a new set of sprockets in addition to new chain). If your sprockets are used/old & all you did was install a new chain...then you could be right on that second notch at the back of the swingarm or just past the second notch.
Now, you say you have a couple thousand miles on the new chain...& judging by your pic, you're just past that second notch. <---- If that's true, then your chain is where it should be. There ya go.
If you need a pic, I'll see what I can do.
Old Oct 21, 2010 | 12:47 AM
they are new stock sprockets, ive put 2000 miles on it and im just past the third notch.
that is too much isnt it?
Old Oct 21, 2010 | 12:53 AM
OutlawF4's Avatar
If the sticker was in the right place, it would be in the "new" area so its fine. I just put my chain on and its on the 3rd mark in the "new" area.
