Chain lube
I use PJ1 Black Label
It's not so much an oil, more like a wax.
Do not use wd-40, I hear it eats the seals and oil won't stick.
I also use a "grunge brush" to get the old stuff off with amild degreaser.
A rear stand helps out a lot while doing this.
You will also want to warm up the chain b4 applying new lube (take it for a quick spin)
The heat from the chain allows the lube to penetrate to the seals better.
Every 500 miles or so is a goodinterval.
Do not leave you chain unattended, bad things can happen.
also, watch your fingers.
Clean and lube the chain every 500 miles.. sooner if you're riding in the rain alot or real dusty/dirty conditions. Bel-Ray Super Clean chain lube is also another excellent lube to use. That's what I use and from what everyone has told me it's one of the best. Doesn't fling at all and sticks on there forever.... good stuff!
Don't forget to check the chain freeplay often too, and keep it adjusted properly. And be careful of your fingers.... I just had a buddy lose a finger in a chain cleaning acciden't a couple weeks ago... wasn't pretty [:-]
cBrentb
Apr 25, 2013 08:14 PM
