Chain lube?
Alright this probley gets asked a lot but what chain lube do you guys use? I have been using motul off road chain lube but it slings a lot and I get a huge build up of grease that drips down on my fairing by the kickstand. Any idea if I'm using to much or could it just be the type of chain lube I use? Any recommendations on a different chain lube would be great also. Thanks guys.
I recently starting using pb blaster dry lube. Seems to work well. Not sure if anyone else has experience with that.
In the past I used to use maxima or castrol chain wax.
Just an FYI, many people I have talked to use nothing but WD40 with nothing but good results.
I just went to the motorcycle shop and picked up some (the writing in swedish) cleaner and lube. I'm sure it's pretty much all the same.
For us skateboarders, we don't use WD40 to lube the wheel's bearings because even though it cleans and lubes well, it attracts too much dirt and debris to be effective, so I don't use it on the chain. JMO.
O ring or X ring chains are sealed. Some people don't ever use any lube on their chains because pretty much everything I have ever seen will attract dirt to some extent, they clean the chain often and just let the lube inside the sealed rings to do its job.
I am pretty sure that skate board bearings (if anything like inline bearings) are not sealed, which is why WD40 is horrible for them.
Petty much what I was talking about. Modern chains are pretty awesome. Even cheaper ones hold up fairly well.
