CBR954 Jerking Slipping Chain Sound Low Speeds
Old May 14, 2023 | 05:45 PM
TheScissorman's Avatar
Default CBR954 Jerking Slipping Chain Sound Low Speeds
Hi guys,
Bike has developed an issue. When shifting from 4th to 5th it feel like it’s not engaged 100% and causes a jerking motion and a loud (ish) noise that I can describe as a chain skipping sound.
The gearbox generally feels tight and the above issue does not happen when I ride through all the gears up to 8/9k rpm. It only happens if I’m in a higher gear at about 50mph and then accelerate hard in 5th that the slipping sound and jerking occurs. If I drop to 3rd and go through the gears then it doesn’t happen. It appears to happen only under heavy load in 5/6th at lower speeds.
Clutch bite is great, no slipping clutch at all so I’m pretty sure it’s not a clutch issue. It sounds like it’s trying to get into 5th gear for a second, slips and judders and then it’s smooth and pulls.
Some guys in FB said could be the following:
Clutch, dogs, clutch adjustment, oil, chain too tight, chain too loose,….I’m baffled!
The chain is a bit tight (25mm free play) and the front and rear sprocket at all good, no worn teeth.
Anyone had the same issue or can someone diagnose?
Hope you can assist me.
Great forum BTW.
Old May 20, 2023 | 11:56 AM
Welcome to the forum, that sounds like a strange issue, hopefully one of the guys with the early blades might be able to help.
In the mean time lets see some pics.
Old Mar 16, 2025 | 11:56 AM
htm139's Avatar
Hi
Did you ever get it sorted as our 954 is doing the same at low speeds in first and second gears after about 20mph the feeling like the chain is jumping goes away.
Old Mar 16, 2025 | 11:59 AM
Originally Posted by htm139
Hi
it was 2ng gear dog teeth in the back of the gear. The were worn so slipping and not engaging properly. Engine out job for me. Have a look at my YouTube (Mid Bike Crisis) as I filmed some of it. Might help you a bit.
Old Mar 16, 2025 | 12:03 PM
htm139's Avatar
Thanks for the reply.
sdenny
Jul 27, 2012 10:11 AM
stlcbr600f4_newb
Jul 18, 2012 05:12 PM
LocRider
Nov 30, 2010 11:10 PM
mullenc525
Feb 8, 2010 11:10 PM
fastcbr
Mar 4, 2009 05:44 PM
