CBR600RR 06 MOTOR SWAP
Old Nov 13, 2007 | 04:51 PM
DC180's Avatar
Default CBR600RR 06 MOTOR SWAP
I HAVE A 2006 CBR600RR AND I WAS WOUNDERING IF ANY ONE KNOWS IF THERE IS ANY WAY TO DO A MOTOR SWAP TO A BIGGER MOTER LIKE A 929 OR A 954 OR EVEN A 1000.
THANKS
Old Nov 13, 2007 | 05:24 PM
knightslugger's Avatar
Default RE: CBR600RR 06 MOTOR SWAP
nope. unless you can fabricate really well... the only motor that will fit in a 2005-2006 CBR600RR frame is a 2005-2006 CBR600RR motor.
Old Nov 13, 2007 | 08:09 PM
Jason748's Avatar
ORIGINAL: knightslugger
Actually the 03-04 bolts right in too...
But kightslugger is right, possible - Yes, but it'll take a fair amout of fab work to do.
Old Nov 13, 2007 | 08:43 PM
ORIGINAL: Jason748
i thought the 03/04 had slightly different mounting points. different frame and all. maybe it's just the fairing stays that were different.. ****, hell i can't remember now. damn it...!
Old Nov 13, 2007 | 09:52 PM
Jason748's Avatar
The frames are almost identical. The only real different mounting points are the 05/06 has an additionl mounting point underneith the framebehind the engine for an exhaust mount. If fact the engines are indenical from the cylinder down - the head,throttlebodies &airboxare different, and a few sensorsbut other than that nothing changed engine wise. Even the fairing stay is the same.
I actually helped a friend convert his 04 into a 05, we basicially bolted everything from a 05 with a broken frame on to a 04 frame with on problems. We had to mix and match afew minor brackets depending on which parts we used, but everything bolted rightup.
Old Nov 13, 2007 | 09:55 PM
must have been the way that the fairings mounted up then...
Old Nov 15, 2007 | 12:33 AM
topbuzz's Avatar
no disrespect but why don,t you just get a fireblade it,s much easier if you want a bigger engine get a bigger bike
torq215
Feb 19, 2012 08:34 AM
HOLDINGITBIG
Feb 20, 2009 08:03 AM
z28forlife
Mar 12, 2008 09:04 PM
jiveturky
Aug 30, 2005 09:27 PM
