CBR600RR 06 MOTOR SWAP
RE: CBR600RR 06 MOTOR SWAP
ORIGINAL: Jason748
Actually the 03-04 bolts right in too...
But kightslugger is right, possible - Yes, but it'll take a fair amout of fab work to do.
ORIGINAL: knightslugger
the only motor that will fit in a 2005-2006 CBR600RR frame is a 2005-2006 CBR600RR motor.
The frames are almost identical. The only real different mounting points are the 05/06 has an additionl mounting point underneith the framebehind the engine for an exhaust mount. If fact the engines are indenical from the cylinder down - the head,throttlebodies &airboxare different, and a few sensorsbut other than that nothing changed engine wise. Even the fairing stay is the same.
I actually helped a friend convert his 04 into a 05, we basicially bolted everything from a 05 with a broken frame on to a 04 frame with on problems. We had to mix and match afew minor brackets depending on which parts we used, but everything bolted rightup.
