CBR 929 not starting (help)
Old Apr 15, 2006 | 03:12 AM
midwest mayhem's Avatar
Default CBR 929 not starting (help)
ok here's the deal i have an 01' 929 this bike was once a stunt bike and now i'm putting the factory plastics back on and ran into a problem! the bike started up just fine for 3 years stright it sat for about 8 weeks then i go to start it and the fuel pump will not come on, i've been trouble shooting for a while and this is what i have so far-
all fuses are good, the tip sensor has been off the bike for years it was just jumped at the connection to loop it for stunting reasons so that's not it, i just put on the new tank and put the pump in and hot wired it to the battery and it comes on just fine, but dosent come on when it's hooked up and i go to hit the on switch and it has nothing. battery is good and cranks just fine but no fuel pump at all i have no idea what to do next any help at all would be amazing thanks!
Old Apr 15, 2006 | 05:48 AM
DThompson's Avatar
Default RE: CBR 929 not starting (help)
Could be your kill switch or your kickstand sensor
Old Apr 15, 2006 | 06:29 PM
CBR600RRBLUE's Avatar
Make sure the instrument panel is hooked up and in good working order now i say that because a 600RR will not activate the fuel pump without it. I dont know anything about a 929 but if its injected then it probably does, hope this helps
Old Apr 16, 2006 | 02:18 AM
slowpoke's Avatar
ORIGINAL: midwest mayhem
... i just put on the new tank and put the pump in and hot wired it to the battery and it comes on just fine, but dosent come on when it's hooked up and i go to hit the on switch and it has nothing...
So the fuel pump is good. Carbed bikes have a fuel pump relay that can go bad. See if your fuel-injected bike has a fuel pump relay.
Old Apr 28, 2006 | 11:20 PM
just found out the problem it was a fuel relay under the seat got weat and burnt up! just picked one up from honda for $27.00 fired right up thanks.
BlackDogIron
Sep 14, 2017 05:47 PM
Nevets
Nov 8, 2010 04:45 PM
BrokeCollarBone
Nov 24, 2009 01:24 PM
bh1
Dec 7, 2007 02:36 PM
steeper
Jun 23, 2006 02:49 PM
