cbr 600 needs choke to run
Old Jul 4, 2007 | 08:55 PM
detthrasher's Avatar
Default cbr 600 needs choke to run
1987 cbr 600. had been sitting. sprayed the cards with cleaner, replaced fuel pump, new plugs, new fuel, starts and idles great with choke. if turn choke off or try to rev it up will die.
any suggestions?
Old Jul 4, 2007 | 11:24 PM
ThisisMickey's Avatar
Default RE: cbr 600 needs choke to run
Ya it sounds like your Idle Rpm's are too low. Try to raise your idle speed.
Old Jul 5, 2007 | 12:37 AM
AudiCBR's Avatar
well, i'd definitely make sure its burning normally(pull plugs and check to make sure its a brownish color). it sounds lean and the choke just adds the extra fuel to make it run. its probably because it sat for so long and may have tons of gunk built up in the carb. I'd pull the carb off personally and make sure it got rebuilt just to be safe. You could always just try adjusting the carb too and see where u stand.
Old Jul 5, 2007 | 04:09 PM
Scrufdog's Avatar
yeah, might be as simple as adjusting the idle ****
cuetip
Jul 28, 2012 03:56 PM
mbrown22
Nov 23, 2010 10:37 AM
dalves11
Sep 22, 2010 04:47 PM
pacemaker
Sep 26, 2009 11:32 AM
pointman
Mar 14, 2007 09:58 PM
