cbr 600 f4 overheating
Old Jan 25, 2008 | 01:58 PM
jadefox's Avatar
Default cbr 600 f4 overheating
Hi guys, i have a 99 600 f4. sometimes in heavy traffic, slow speeds, overheats blowing out the coolant. the temp gauge is reading 2/3,but not in the red, not sure if the fan is coming on while moving slow in traffic. once when i turned the motor off, the fan did come on. does anyone else have this problem.
Old Jan 25, 2008 | 02:14 PM
Nauree's Avatar
Default RE: cbr 600 f4 overheating
2/3 in the guage is normal if your sitting in traffic.
Old Jan 25, 2008 | 02:32 PM
Lrn2Go's Avatar
The coolant overflowing doesn't sound good... but up about 2/3 the way when sitting in traffic is no big deal. My temp guage is digital, and I saw 222 degrees while I was stuck waiting for a crash to clear up yesterday... and the outside temp was about 34 degree's. (When I was moving, average temp was about 163... so that's a 59 degree difference!)
Make sure you aren't overfilling the coolant and, though I don't know how you do it on a bike, only on cars, make sure there's not any air trapped in the system. Oh, and make sure you've got the correct anti-freeze to water mixture.
Old Jan 25, 2008 | 03:03 PM
Nauree's Avatar
ORIGINAL: Lrn2Go
+1
You dont fill the reservoir all the way to the top. Theres a min and max line which is ironcly near the bottem of the reservoir.
Old Jan 25, 2008 | 05:08 PM
jadefox's Avatar
checked level in reservoir was at the max level, the other day. not sure what temp fan is supose to kick in. iam thinking maybe thermostat needs replacing???
Old Jan 26, 2008 | 01:31 PM
Lrn2Go's Avatar
If it has boiled some out, and you've not put any more in, and NOW it's at the max level... then you had too much coolant in the system and it boiled out the extra, and you should be good now.
Old Jan 27, 2008 | 01:42 PM
Tahoe SC's Avatar
if you have proper level of coolant in there and it's blowing out still, then your problem is lack of pressure in your cooling system causing the coolant to boil at much lower temps than what it's supposed to.
this is why your gauge only reads 2/3 the way.
i'd check the radiator cap.
aan310
Oct 7, 2013 06:34 AM
StriperAngler
Jun 27, 2010 10:15 PM
tommyo4
Jun 9, 2010 05:12 PM
tommyo4
Jun 1, 2010 11:25 AM
98dakota
F2 Tech
Mar 29, 2010 10:10 AM
