CBR 1000rr shifting question
Old Nov 17, 2012 | 05:03 PM
ryan23's Avatar
New Member
Default CBR 1000rr shifting question
so i recently purchased a 2011 cbr 1000rr with 4600 miles. i used to ride an 05 r6 and shifting from first to second was no problem, the shift level was easy and went into second with barley any effort from my foot. now all a sudden on my 2011 cbr i can hardly lift the lever to get it into second and it always will go into neutral first. is this common just because the bike is new and needs to get worn in or is something wrong?
Old Nov 17, 2012 | 06:01 PM
MadHattr059's Avatar
Try adjusting the lever lower.
If it's too high, you don't have any leverage with your toe.
One of the most common errors of new bike ownership,
not adjusting a bike's controls to your body.
If that's not the issue, double-check the slack in the clutch cable.
It should only have 1/4" to 3/8" of play. Any more than that, possibly,
you might not be fully, dis-engaging the clutch.
Hope this helps, Ern
Old Nov 17, 2012 | 08:08 PM
ryan23's Avatar
New Member
The lever is already as low as it can go and I adjusted the cable to where it would move if I let out barely at all. It hurts my toe when i try to shift up cause its that difficult to move it
Old Nov 17, 2012 | 08:22 PM
74demon's Avatar
IMO, something is wrong. Should be able to shift it like a hot knife through butter.
How are the other gears?
Old Nov 17, 2012 | 09:08 PM
ryan23's Avatar
New Member
idk how the other gears are...i bought it two days ago and so far ive only been in first and second.
Drumsergeant
Aug 17, 2014 09:38 AM
ceazur
Mar 30, 2010 12:25 PM
Cypress_CBR
Apr 26, 2007 11:44 PM
COspringscbr954
Jul 22, 2006 02:30 PM
ericmxzx440
Oct 12, 2005 01:59 AM
