Carburetor Question
Old Aug 22, 2007 | 09:41 AM
wussola's Avatar
Default Carburetor Question
I have 1997 CBR 600 F3. I installed a V&H SS2R slip on and K&N filter a couple years back. This winter I installed a Dynojet stage 1 jet kit per the kits specs. The bike runs excellent (has more response and pull) after installation of the jet kit. I'm very happy with the results.
My question is that the bike seems to respond crisper and pull harder when it is cooler compared to when it reaches operating temperature? Any ideas why this is? Do the carburetors need some fine adjusting? Not sure if the bike is running a little lean or rich. The plugs look normal (not white or black).
Let me know of any suggestions ... thanks!
Old Aug 22, 2007 | 12:08 PM
MikeInCtown's Avatar
Default RE: Carburetor Question
Cool air provides more oxygen and generally less humidity. Therefore, you are able to pack more air into the cylinders and you get a lot more power from the burn/combustion cycle. You should check your plugs for a black soot. if you have the black soot, you could need to get the carbs adjusted because it's running rich.
Old Aug 23, 2007 | 04:55 PM
wussola's Avatar
OK ... thanks.
I think my next project is to sync the carbs and then experiment with the pilot's a little ...
Old Aug 24, 2007 | 08:22 AM
BTW, I've read from may people that the two middle carbs tend to dump more fuel than the outer two because placement of the fuel lines. I've heard recommendations that you should have the two middle carbs one size jet down from the two outer ones. Don't know if it's true, but the plugs will show you as well as an expert engine tuner. (I wouldn't even listen to the mechanics at my local shop in most instances)
cgalvan
Aug 28, 2010 05:27 PM
Griffin
Aug 3, 2009 09:27 PM
SlavDog
Dec 23, 2007 12:38 AM
SIRGERMAN
Nov 13, 2007 07:35 PM
Bobthebiker
Nov 21, 2006 11:38 AM
