Can't start my Bike, Help!!
Its a 05 CBR600RR
So on the Freeway today, I got cut off by a chrystler 300, and I had to hit the brakes hard. I popped my back wheel up in the air and then dropped it back down and continued on my way. When I got to my destination about 5 minutes later, I turned off the engine, then I couldn't start it again. It acted like it had a low battery. I'm not sure if I could've jarred something loose, or anything like that. So at first it was acting like I had a low battery and then it started to reset the bikes computer everytime I hit the ignition. Then it started to grind when I hit the ignition. I don't really have any experience troubleshooting the bike. I just recently changed the oil for my first time. any help would be greatly appreciated. I'm sure its a simple fix.
RE: Can't start my Bike, Help!!
Yeah, slamming the back down on the ground sounds like you could have knocked something out of kilter. check your battery terminals, the wiring connectors around the regulator (right hand side rear, under the frame rail).
www.stephygee.com/
You can get a workshop manual for yer bike here, it should have a trouble shooting guide, but more important where everything is.
www.stephygee.com/
