Can I avoid tapping engine?
Old Dec 14, 2011 | 01:06 PM
  #21
danroonie's Avatar
Originally Posted by G_954rr
The aftermarket bolt I got had the exact same flange and everything.
The bolt drama continues... I got the bolts from Fastenal and the bolts were unusable - the bolts were partially threaded like OEM HOWEVER the bolt shaft was 6mm on the OEM bolt the unthreaded shaft was ~5.3mm. The fat bolt shaft will crush any threads it hits inside the stud. The spec sheets on the Fastenal site don't show the important information about the bolt's shaft and the amount of threading - and 1/2 were missing. I've called and emailed Fastenal and am awaiting a response.
Given what @GR954rr said, I called nuttybolts (760) 948-2658 and they DO have inventory that isn't on their website. Not quite partially threaded like OEM, but fully threaded - so it should work with a few extra turns of the wrench. If that's the best I can do (ie. I don't hear from Fastenal soon) I'll have them mail them to me. I'll take their salesman's word that even though they're not stamped they actually are 8.8 hardened.
Old Dec 14, 2011 | 05:10 PM
  #22
rayall01's Avatar
you can carefully thread the shank higher, it's what i'd do in this situation. lots of oil, and very slow, and even an 8.8 will yield. especially since you only have to go a small amount.
soul!!!!
Aug 25, 2019 10:19 PM
xxlostrealmxx
Jul 24, 2009 03:16 PM
TripsD
Mar 1, 2009 01:44 AM
SUPERMAN_ON_929RR
Apr 3, 2007 01:52 PM
jxc574
Jul 3, 2006 01:00 PM
