engine tapping real loud
Old Aug 16, 2010 | 03:02 PM
soul!!!!'s Avatar
Default engine tapping real loud
this is what happened. i redlined my bike in first and second gear and motor started knocking loud.slowed down oil light came well blinking on and off and bike killed.started it back up now it has a bad tapping noise oil is full......oil light not comming on anymore.......and it only does it when i rev it not at a idle at all........any help would be great thx.
Old Aug 16, 2010 | 06:48 PM
kilgoretrout's Avatar
Administrator - Retired
Was the oil full the whole time or was it low and then you filled it up after the fact?
Loud tapping and oil lights is usually not good.
Old Aug 17, 2010 | 08:27 AM
soul!!!!'s Avatar
it was full at the time it happened
Old Aug 17, 2010 | 08:45 AM
R Dub's Avatar
October 2011 ROTM
Sounds to me like you hurt the motor. If it is a tapping then its probably the valves. If its knocking then you probably threw a bearing, most likely a connecting rod bearing and the motor will have to be torn apart to fix.
Old Aug 25, 2019 | 10:19 PM
kmaneage's Avatar
New Member
Sounds like you broke a valve spring. Check your oil pan and see if you have shavings on your plug
kowen1208
Jun 15, 2013 11:03 PM
daneb2087
Mar 21, 2013 02:59 PM
STRETCH15
May 12, 2011 08:13 AM
94cbr900rr
Jul 7, 2010 10:29 PM
harrison
Oct 30, 2007 07:53 PM
