rattle after change
Old May 8, 2011 | 04:23 PM
STRETCH15's Avatar
Default rattle after change
Ok guys today I changed my oil for the first time. By the way its a 2002 f4i. I put mobile 1 back in it let it run for about 5 minutes, turned it off. About 10 minutes later I went for a ride motor is ticking bad now its really loud I put 3q in it was that enough oil or did I need to put more
Old May 8, 2011 | 07:25 PM
tanrush's Avatar
I believe it is 3.3 quarts. Check your oil with it upright and look through the sight glass on the right side.
Old May 8, 2011 | 08:08 PM
STRETCH15's Avatar
Ya I checked that I see the oil but the motor is sounding like it would as if there was no oil or a blown motor
Old May 9, 2011 | 03:00 PM
jp_greenville13's Avatar
What weight oil did you use?
Old May 10, 2011 | 07:09 AM
STRETCH15's Avatar
I used 10-40 mobile 1
Old May 10, 2011 | 08:44 AM
ButkoF4i's Avatar
has the CCT been replaced on it?
Old May 10, 2011 | 10:59 AM
STRETCH15's Avatar
Ya I changed it I makes that sound at about 5 to 6 k and above
Old May 10, 2011 | 11:11 AM
fourxchevy's Avatar
The person I bought my 02 from changed the cct at 4500 miles with another oem one, it went bad again at 9000 miles and I put in a manual one. I did have to readjust it again at about 15000 miles.
Old May 10, 2011 | 03:12 PM
ButkoF4i's Avatar
could be the CCT..where do u hear the knocking sound from?..topend?..mine sounded like knocking before i replaced it with a manual..
Old May 10, 2011 | 03:13 PM
ButkoF4i's Avatar
if it makes that sound around 5-6k then its a good possibility it could be ur CCT
