Which Cam lube and engine assembly oil for a rebuild? Also what to replace?
Old Sep 17, 2018 | 08:21 AM
Pmartone's Avatar
Default Which Cam lube and engine assembly oil for a rebuild? Also what to replace?
Which Cam lube and engine assembly oil for a rebuild? Also what gaskets and bolts to replace?
Old Sep 17, 2018 | 12:56 PM
tentacleslap's Avatar
I used Redline Assembly Lube. Seemed to work well. The oil is a personal choice, but if it's only gonna be used for breakin, I wouldn't bother with anything fancy. I used mineral oil
All the gaskets should be replaced, definitely the head gasket, along with anything else that you don't want leaking or would be a pain in the *** to replace after the fact
Replacing the bolts is a personal choice. I didn't bother. The exception is any pinch bolts are considered single-use. They are commonly used for conrods, and maybe some other locations as well. Consult your manual, as they'll spell it out
You'll probably also want to do valve stem seals and any o-rings while you're at it
What are you rebuilding?
Old Sep 17, 2018 | 01:51 PM
Pmartone's Avatar
Where do you apply the assembly lube, and where do you apply the mineral oil?
I’m rebuilding my F4i. Dropped it and bent the crankshaft. It’s my first rebuild so I want to do a punch list before I rebuild it.
Old Sep 17, 2018 | 02:03 PM
Tentacleslap probably won't mention it 'cause he's to modest but he has an outstanding video series on here concerning rebuilding an engine. You may want to take a look at that. It's packed full of how-to's.
Old Sep 18, 2018 | 10:07 AM
Aw shucks
Pmartone - you should start a rebuild thread. I (and others I'm sure) would happily follow along. It's a good idea to check availability/price on everything but I'd hold off on ordering parts until you make sure the engine can be saved. Taken as a whole, a rebuild is a lot of hours, but not a lot of difficulty, mostly disassembly and inspection. Reassembly is 90% waiting on parts that you forgot to order and 10% trying to fit small parts in impractical spaces. Firing it up is like the best parts of Christmas mixed with the worst parts of a rollercoaster
Generally, the assembly lube will go everywhere where two pieces of metal will rub up against each other. Bearings, cams, etc., but it's too thick to use in cylinders or transmission. Use oil for those. It's all in the manual
Any questions just ask
Old Sep 18, 2018 | 05:57 PM
ceebeeaarguy's Avatar
+1 for redline assembly lube. I used it when I did valve reshimming. Applied generous amounts to all the lobes on the crankshaft etc.
Are you doing a full rebuild or just top work?
Boris.b
May 27, 2019 11:56 AM
optytrex
F2 Tech
Feb 27, 2015 03:44 PM
Chefohboy
Feb 24, 2014 12:09 PM
Ivanivanovich
Oct 25, 2013 08:24 AM
