Cam chain tensioner
I have already changed the cam chain tensioner on my CBR600F4 (automatic one) but I was told that it will go again in a few thousands miles. Has any of you guys fitted a manual one? and if so, how do you know when to adjust it? Is there a risk of overtightening, or is there any other way of knowing when to adjust it and by how much?
Cheers
Cheers
I'm not positive (as i was told by several dealers) that there was a recall on the older model CCT's. I think it was up to '03 or '04 but supposedly, the new ones work fine. I have over 6k on my oem one and no noises of any kind. Your new one should be fine.
If the stories I heard are BS, then APE seems to make a good one. You tighten it until you hear the chain making noise, then you back it off a little. If it's over tightened, it'll make a lot of noise and wear out the delrin chain slider.
