Bubbly Engine Sound on Decceleration
Old Aug 5, 2009 | 12:59 PM
Ruckus1987's Avatar
Default Bubbly Engine Sound on Decceleration
Hey Everyone,
My engine has started to run a bit differently, and I most noticebly can hear a sort of louder, deeper, sort of bubbly sound when I'm downshifting which starts at about 4 thousand rpms until I pull the clutch in and totally stop the bike. I had the carbs tuned about 4 weeks ago, and this problem started about 2 weeks ago.
My power is still fine, and everything else seems to be ok. I was wondering if this could be a problem, or if it is just the new sound my engine is making due to the carb adjustment?
Old Aug 5, 2009 | 08:30 PM
Todd84's Avatar
It probably has to due with the carbs being sycned
Old Aug 6, 2009 | 03:58 PM
johnnyx's Avatar
Could be an exhaust leak, could be a carb is running rich from poor tuning. Could also be a cylinder misfiring. Checked your plugs lately?
Old Aug 6, 2009 | 04:09 PM
cageless's Avatar
repack you exhaust
Old Aug 7, 2009 | 11:11 AM
Ruckus1987's Avatar
The sound is coming from the engine, and not the exhaust itself. I am going to check the spark plugs tonight and make sure they are good. I'm thinking my header may be leaking...? But wouldn't I see some kind of smoke in my exhaust if this was the issue?
Old Aug 8, 2009 | 09:26 PM
toddmonster's Avatar
I am going to agree with classic here on this one however your bike could be running a little too lean when you check the plugs you are looking for a nice tan color if it is white you know what the problem is too much air. let us know what oyu find
Old Aug 11, 2009 | 12:58 PM
Ruckus1987's Avatar
The bushings on my front tire started going to crap out on the weekend due in part to the terribly uneven wearing on my tire I'm sure. I took my bike in to get a new tire/bushings and they are going to take a look at the engine as well. I will let you know what their conclusion is about the engine sound.
Old Aug 11, 2009 | 02:16 PM
johnnyx's Avatar
I actually developed a similar sound while accellerating under 6k recently and it turned out to be a carb sync issue.
CJardine
Mar 7, 2012 04:00 AM
Turbulenz
Oct 18, 2010 09:13 PM
DragonCBR
Sep 1, 2008 12:27 AM
CosmoBob
Apr 14, 2007 04:21 AM
eristole
Jun 19, 2006 07:53 PM
