brake pad clearance's//.007-any suggestion
Old May 22, 2007 | 08:52 PM
900nos's Avatar
Default brake pad clearance's//.007-any suggestion
took bike to local dealer,,
hasnt been right since..
closer inspection, revealed when new tire mounted they had the disks @!&U backwards.
took off tire/ swapped out disks to correct sides,, but cant get honda recommended .007 clearances on
either pad on either side of each caliper.. any suggestions??? manual says adjust two bolts for tolerance..
cant figure out the issue, bled brakes before,think they need it again,? but wouldnt the pads come back out like on a vehicle.
have 2 year degree in automechanics.. bikes are different,
thanks in advance,
michael
Old May 22, 2007 | 10:09 PM
900nos's Avatar
Default RE: brake pad clearance's//.007-any suggestion
Got it,
had to loosen axle, and loosen outer bottom fork bolt,
pull out on fork/caliper, got clearance ..tightened back and double checked...
good to go.
Sprock
Oct 24, 2010 02:44 PM
KidCr3nshaw
How-To: Mechanical
Mar 13, 2008 11:21 AM
woodyracing
May 17, 2006 06:16 PM
brancart1
May 15, 2006 09:24 PM
RRip
Jul 22, 2005 11:17 AM
