Brake Lever guard cbr600f(x) 99
Old May 13, 2024 | 05:09 PM
W3jltcbr's Avatar
Default Brake Lever guard cbr600f(x) 99
hi, I am wanting to do a track day in the UK on my Fx99 and the track day provider requires a brake lever guard. I see a few online with different sizes. I thought it would be simple case of it screwing int to the thread that the bar ends screw into, but no, apparently you have to remove the internal bar weights and then fit a lever protector using an expanding bolt type affair. surely there have to be a bolt in one available to just replace the bar ends?
Can anyone show me how they have done this?
Thanks
James
Old May 19, 2024 | 03:12 AM
dannoxyz's Avatar
You can remove expander from lever guard. Then add spacer between factory nut inside bar out to lever guard. Similar to stub of bar-end weight that fits into bar. Much more secure mounting than expander wedge.
Old May 22, 2024 | 03:36 PM
W3jltcbr's Avatar
Thanks for this idea! Did a version of it this evening and kept the original bar weights inside the bar. worked well.
Old May 23, 2024 | 02:22 PM
dannoxyz's Avatar
Awesome job!! Please post photos or diagrams of your install if you have any.
Old May 23, 2024 | 03:31 PM
W3jltcbr's Avatar
Not sure if my attempt warrants a pictorial how to guide. Its not perfect by any means but i'm ok with it.
flipper1939
May 9, 2011 02:51 AM
MonTEGA
Feb 21, 2010 08:26 PM
gabester76
Oct 5, 2008 05:59 PM
XM23
May 30, 2006 10:23 PM
