brake disc - I need help
Hello!
I have a cbr 600f4 and a problem with my front break disc's and the blocks. In the owners manual is the following written:
"Check the clearance between the brake and caliper bracket on each sider after installation. The clearence should be at least 0.7 mm."
I change my break blocks in the front on both side's. But after I activate the break lever, the blocks are at the brake disc. There is no clearence between the break disc and the blocks also I adjust the cradle bevore I tighten the pinch bolts.
What can I do?
Thanks
Tom
What can I do?
Thanks
Tom
