Bleeding Calipers
Old Sep 11, 2008 | 07:36 PM
radvoem's Avatar
Default Bleeding Calipers
how to?
is it similar to automotive bleeding
hold down lever, open bleeder, purge, close bleeder, repeat
that sound right???
looking to replace the fluid its old
Old Sep 11, 2008 | 10:42 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: Bleeding Calipers
I do it exactly like auto. I usually open them up and let gravity bleed till i get clean new fluid out of both fronts, close the bleeders, then pump the lever 3-4 times and hold. Open a bleeder till the handle is half way down and close it. Do this 3-4 times per caliper to make sure all the air is out. Rinse and repeat for the rear. I have done this countless number of times and never an issue.
Old Sep 13, 2008 | 01:26 AM
Mstngdrew232's Avatar
When I switched to my SS lines I used a little vacuum thing to make sure that no air seeped back into the system. It was very helpful in getting my system bleed successfully, I have heard of people having troubles trying to get their system to be 95% or better.
Old Sep 13, 2008 | 10:40 AM
radvoem's Avatar
thanks for your input guys i appreciate it alot homies
rad
Old Sep 13, 2008 | 11:53 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Just do not let the reservoir run dry ... you will play hell getting all the air out then. A mity-vac makes the job real easy.
Kuroshio
Apr 22, 2011 01:12 PM
wolfy01
Mar 18, 2009 04:30 AM
radvoem
Sep 13, 2008 10:38 AM
TennesseeCBRF2
Sep 30, 2006 12:06 AM
morpheous283
May 4, 2006 05:40 AM
