Ororo's bleeding
Looks pretty bad too. Just changed the oil on Monday. Took her for a test ride after and didn't see any leaks. Rode into work today and noticed an oil spot under her. Back at the apartment, there was another in front of the door where I park her.
She didn't leak till the oil change (ugh... Mobil 1 blood is expensive). I checked the drain plug and tighten it but I think she's still bleeding. Only other thing it could be (since it was th only thing touched) is the filter. But the leak is directly under the drain plug and the plug is wet with oil. I didn't overtight the plug or strip the threads. Hand tightened and then 1/4 turn more. Tonight I took the torque wrench to it and put it to spec.
Any ideas?
Any ideas?
