bike wont start in gear.
Old Feb 2, 2011 | 11:46 PM
LJ Harp's Avatar
Official CBRF Decal Man
Default bike wont start in gear.
so ill be riding in town and will stall because my bike is still acting up with the throttle because the carbs still need synced. I have to put the bike back into neutral and then start it again. i was wondering if this is normal or is something wrong.
kick stand is up because ill be riding, also the bike does not stall when put into gear at all unless the stand is down so im guessing its something to do with the clutch
Old Feb 2, 2011 | 11:57 PM
jp_greenville13's Avatar
Sounds like a bad clutch switch
Old Feb 3, 2011 | 12:24 AM
LJ Harp's Avatar
thats what i was thinking but my experience with bikes isn't a lot. where is this located I cant find the switch and I don't want to replace the whole clutch mount
Old Feb 3, 2011 | 10:29 AM
TimBucTwo's Avatar
+1
look for wires going into the pivot point of the clutch lever.
Old Feb 10, 2011 | 10:20 PM
bumblb's Avatar
If you have a multimeter check to see that the switch opens and closes and that will determine if the switch itself is bad. If not then you'll need to look elsewhere.
Old Feb 10, 2011 | 10:24 PM
LJ Harp's Avatar
so what my plan is and what i have done is just to bypass the clutch switch tested it and it starts up all is well now
Old Feb 11, 2011 | 01:56 AM
AZMechanic's Avatar
Just make damn sure you have the clutch pulled in when you hit the starter switch. It's there for safety. But, I'm sure you know that much. Just wanted to throw caution out there. Also, if you race, some tracks will check for the safety switches working correctly before letting you on a track.
Josh_With_The_CBR
Dec 1, 2008 09:48 PM
Josh_With_The_CBR
Nov 26, 2008 09:37 AM
Jin
Jul 20, 2008 07:20 PM
tagger609
Jun 27, 2008 02:09 PM
bartkid21
Apr 25, 2007 01:43 PM
