Bike won't start in first gear
Old Sep 26, 2006 | 10:55 AM
voodoochyl's Avatar
Retired Moderator
Default Bike won't start in first gear
So, I just changed the hand grips and levers on my '06 F4i, and now my bike will start in neutral ONLY. I've tried to start it in first (with the kick stand up, and with the clutch engaged), but nothing doing. Can someone offer a suggestion?
Old Sep 26, 2006 | 11:17 AM
dwhite645's Avatar
Default RE: Bike won't start in first gear
That's weird. If you start it in neutral and shift into first does it stay running?
Old Sep 26, 2006 | 11:33 AM
joesrods's Avatar
If you wanna start in first gear you need to have the kickstand up and clutch NOT engaged, meaning pull the clutch lever in, not out, it should start than. If it still doesnt start, when you start it in nuetral are the rpm's really high? If they are, the F4i has a switch that prevents the bike from being started if a lot of throttle is applied, so if you installed the handgrips incorrectly or with them pulling on the throttle cable, it may prevent you from starting the bike. I hope you know what I mean
Old Sep 26, 2006 | 04:06 PM
woodyracing's Avatar
did you unplug the wire going into the clutch perch?
that would cause exactly your problem
there is a sensor that prevents you from starting the bike in gear without the clutch in
matt121
Sep 28, 2011 05:27 PM
LJ Harp
Feb 11, 2011 01:56 AM
Jin
Jul 20, 2008 07:20 PM
