bike wont start after removing and painting clutch cover
Old 04-17-2009 | 08:47 AM
04_CBR's Avatar
Default bike wont start after removing and painting clutch cover
Ok here is the story. My bike was and always ran absolutely great, its an 04 CBR 600 F4i. I have recently be focused on the appearance of the bike and had tons of stuff powdercoated. Well I decided since I couldnt have my bike down for a few days at a time I would just pull the clutch cover paint it with hi-temp paint and put it back on. Everything went back on fine and I let it sit for 3 or 4 days to let the hondabond cure so we didnt have any leaks. I get it out lastnight to take off to the first bike night of the year and it wont start. It will try and turn over just like it normally would but wont start. Can anyone please tell me what I am missing, I know there is the one connector that comes from the inside of the clutch cover and that is plugged up is there something else I am missing? Please if anyone has any ideas please let me know. Thanks in advance!
Old 04-18-2009 | 09:14 PM
trajiks9's Avatar
Could be one of your fuses, I would check the fuel pump fuse. Was it running up until this point?
Old 04-18-2009 | 11:20 PM
justasquid's Avatar
You may have messed up your pulse generator. If you got paint on it or bumped it, it may have broken it. It wont have any spark if its not working. Also, if you moved it all, it may just be out of whack. It needs to be aligned in order to work. I dont know of a way to test it. Its like a 40 dollar sensor.
Old 04-19-2009 | 06:57 PM
toptaz1000rr's Avatar
also if you put the 2 washers back on wrong that go on the starter clutch .. that would do it
if you moved it (the gears) that would do it
if you did not line it up and put the cover on but the 'dowels' inside are not perfectly lined up .. that would do it
Old 04-26-2009 | 10:31 AM
04_CBR's Avatar
Thanks guys it was the pulse generator on backwards. I hate stupid mistakes. Thanks for the input guys.
lillon
02-06-2011 08:39 AM
lillon
02-06-2011 01:36 AM
nsrt4me
08-25-2010 01:16 PM
04_CBR
04-17-2009 08:45 AM
rancidf4i
05-15-2006 02:48 PM
