bike in the trash!
Old Nov 22, 2008 | 11:18 PM
Hurricane rider's Avatar
Default RE: bike in the trash!
I suggest removal of the lower fairings, if not already done, get two jack stands and a good floorjack to lift your bike up by, support under the stator cover and starter side of the motor with the jackstands, and re-assemble your forks properly.
among other things, you also NEED to check your fork oil level now before you close those forks up. chances are you really changed it significantly by not knowingly pushing them up like that. To properly inspect the fork oil height, you need to have some manner of support beneath your bike, like a jack stand, remove the wheel, then the damper rod bolt at the bottom of each fork, remove the spring assembly, and compress the fork to its highest point to measure the fork oil.
THEN put everything back together. damned if I know how much oil to use.
Old Nov 24, 2008 | 08:59 AM
mucamero's Avatar
Good, advice guys, do you think a car floorjack will work?
Thanks
Old Nov 24, 2008 | 01:54 PM
94cbr600kid's Avatar
ORIGINAL: mucamero
Thanks
Yes it will
RenegadeRose
Jun 28, 2013 09:55 AM
AlexF4i227
Jan 12, 2012 03:22 PM
CBRRyder
Jan 12, 2007 07:14 PM
doncollins
Jan 11, 2006 11:59 PM
pitsvtec
Dec 3, 2005 12:33 AM
