Best way to remove oil from tire
Old Apr 11, 2005 | 01:45 PM
bcpower's Avatar
Default Best way to remove oil from tire
Well, I went ahead a punctured my oil pan. I took a right turn at about 25mph right into an oil slick at night - never saw it. I kicked the bike away and it hit a curb. That smashed the header into my oil pan putting a nice little hole/fracture in it. The bike drained in about 5 minutes. I had to ride it off the street before I got plowed but in doing so, oil got sprayed all over the tire, saturating it. I planned on simply degreasing the tire over and over but I'm not sure that this will be sufficient. This has never happened to me before. Is there a sure-fire way to remove all the oil? It's down in all the tread and everything. I'd like to avoid buying a new tire as this one is new.
P.S. - Special thanks to 3rd Street jackets and HJC helmets. Wear your gear... I didn't even get a scratch.
Old Apr 11, 2005 | 02:31 PM
cbroar's Avatar
Default RE: Best way to remove oil from tire
brake cleaner is great for removing oil, should be ok for the tyre but you'd want to check if it will eat the rubber.
Old Apr 11, 2005 | 06:58 PM
chainstretcher's Avatar
Admin Emeritus & MVN
First, glad you're o.k. Sux to go down but always a plus to walk away unscathed! I'm a simple idiot and recommend plain old detergent, water and a soft brush. Brake fluid MAY be o.k. but it is basically just hydraulic fluid and will eat or compromise some types of rubber. I don't know if tire rubber is one of those types. Also, be careful with brake fluid because it will definitely remove paint (don't ask me how I know this).
Old Apr 12, 2005 | 11:01 AM
cbroar's Avatar
NOTE Use Brake cleaner not brake fluid. You can get spray Brake cleaner from any motor store, great for removing oil, grease, tar, asbestos etc... Dont use brake fluid as this will eat your tyres.
Old Apr 12, 2005 | 07:07 PM
thebird_19's Avatar
Well brake spray cleaner as we learned in automotive school is basically rubbing alcohol in a spray can so that will probably work and won't cost as much.
Old Apr 12, 2005 | 09:14 PM
ORIGINAL: cbroar
Doh!! My bad -- it clearly says 'cleaner' don't know why my dyslexic *** read 'fluid'[sm=headbang.gif].
mcastro253
Jun 5, 2012 07:46 PM
CBR327
Apr 19, 2012 07:34 PM
antatious
F2 Tech
Aug 23, 2010 05:31 PM
Joeallmighty
Oct 30, 2006 12:32 PM
DMACK
Jun 4, 2006 07:16 PM
