Remove front calipers before removing tire?
Why do you need to remove the front calipers to take off the front tire? Also the manual says once the calipers have been removed you need to replace the caliper mounting bolts?
You can't just slide the tire out with the calipers still bolted on?
This in on a 94 900rr.
RE: Remove front calipers before removing tire?
When fitting my front tie-down strap (to tuck the front down for drag strip duty) I had to play around with the caliper bolts since that's where you mount the strap, uh, mounts. I just unbolted them and let them dangle for a bit. No harm. And still no problems even with the added stress of the strap when I pull the headlight down to the fender.
