battery linkage
Old Oct 13, 2013 | 12:05 AM
horse_power777's Avatar
Default battery linkage
cbr 600 F 1993
did some work on the bike and bike did not get ridden for a few days. once I ride it again it was running terrible no punch at all. then noticed trouble starting till eventually the bike just died battery flat. charged batt but in a few day same thing. bought new battery and ran great, checked new batt and noticed it was losing charge. I disconnect the negative on the batt and hooked up multi meter to the negative lead and the neg batt terminal and I noticed it was using 5 amps. is this leakage ? I have no alarm or any other device that would drain batt. I then unplugged what I think is the rectifier and performed the same test , result was 0 no leak and noticed the 5 way female plug to rectifier was shattered and brown ie a couple of the connectors where exposed and close to each other.
could this be the culprit?
also please look at pic and let me know if the unit is the rectifier
any thoughts would be appreciated
Old Oct 13, 2013 | 02:43 PM
wes 17's Avatar
The image shows a rectifier yes. I suggest you have a fried one. Check the connector under your seat for heat damage. Once you have unplugged it, check for continuerty between the 3 yellows individually against earth . If theres continuerty between any, theres your problem. If it is the problem, beware this item gets very hot when worked, make sure you mount it to the bike properly before carring out any more work. Hope this helps a bit mate and let us know how you get on mate.
Old Oct 13, 2013 | 05:41 PM
thank you WES when you say check the continuity do you mean from the rectifier to earth or the plug for rectifier to earth ?
Old Oct 20, 2013 | 10:09 AM
Clearly I'm not WES, but I'm sure he's indicating the wiring side of the connector with it unplugged from the R/R (Regulator/Rectifier). Check for continuity from each of the yellow wires to ground. If any of them show continuity, then your Stator would be bad. Also check each of the pins inside the R/R for continuity to ground as well. None should show continuity.
Old Oct 21, 2013 | 02:50 PM
wes 17's Avatar
Default the answer is in the yellows !
Cheerz for filling in for me "i do dirt".......I`ve been busy sorting the garage for the winter lay up for the bike. I agree with you and would still lean towards the r/r being the culprit.
Old Nov 5, 2013 | 11:21 PM
magicbuzz's Avatar
As it so happens, I have just replaced the old rectifier on my 2000 CBR600 F4. The rectifier on my F4 appears to be exactly the same as yours - it was a Shindengen shunt-based regulator/rectifier.
i did some research (on this forum and others) and decided I was much better off replacing it with a newer MOSFET regulator so went and got one. If you want to explore this path, look at Shindengen FH020AA Mosfet Regulator/Rectifier
He has some good videos. You are probably interested in the one which instructs you how to test a regulator. You will need a DMM (digital multimeter) but they are cheap to buy and good to have. The exact numbers aren't important - more that you have consistency.
The videos are at:
Roadstercycle Mosfet Install Videos
The shunt-style test how-to is at:
I have no affiliation with this site except that I'm a recent customer. I wired my new FH020AA in last night and have test ridden since. I'm getting 15V DC out of the regulator and 14.2V across the battery terminals.
Hope that helps!
Dilandau00
Nov 14, 2014 04:53 PM
akrite
Oct 2, 2013 11:04 AM
5p00f3r
F2 Tech
Feb 1, 2012 05:55 PM
killmime1234
Jun 7, 2010 03:03 PM
Foght
Jan 11, 2008 04:52 PM
