Bar Ends
Old Oct 17, 2006 | 06:29 PM
Dave K's Avatar
Default Bar Ends
I can't be this hard! I have an '99 CBR F4 that came to me without bar ends. It has after market grips on it with a place to cut out for the bar ends to slide through the end of the grips. I ordered the LP carbon fiber look ends and though they say they fit, they don't. The internal weights inside the handlebars are present and they are threaded 6mm. The LP bar ends are threaded 8mm. So ok, just change screw size. If I do that, how will the throttle turn, when I tighten the screw? What do I need? Or what are you guys doing?
Old Oct 17, 2006 | 10:20 PM
mikey1297's Avatar
Default RE: Bar Ends
jus change the screw size and se what happens a new screw cant be a couple of bucks
Old Oct 17, 2006 | 10:23 PM
Dave K's Avatar
Mickey, of course I have thought of that, but then is there a spacer required to allow the throttle to function? If you screw it firm, it will prevent the throttle from rotating.
murdocity
Jan 21, 2010 03:21 AM
DBEAU
Jul 15, 2009 09:54 AM
the dog
Oct 15, 2008 03:50 PM
barryem
Aug 10, 2007 08:58 AM
ptowntsi
Aug 2, 2007 12:46 PM
