average oil change cost?
Old Apr 3, 2006 | 11:49 PM
  #21
Funedude05's Avatar
Default RE: average oil change cost?
i just changed my oil today. 4 quarts of Honda CN4 oil for 13 dollars and an oil filter. everything for 27 dollars and change. just FYI
David
Old Apr 4, 2006 | 12:10 AM
  #22
denhou1974's Avatar
I've used the Mobil 1 MC oil before. Got better results with the Motul though. Make sure you don't use Mobil 1 10w-30.
ORIGINAL: IronFox
honda gn4 oil costs about $15 and the filter for mines about $7. Im thinkin about using mobil1 anyone use it?
Old Apr 4, 2006 | 12:34 AM
  #23
Lukercbr600rr's Avatar
Yeah i just did one it costs about thirty bucks. i use 20 50w oil i dont like noise when i used 10 30w the first start up was a little noise but to each his own. Make sure you use motorcycle oil cause car type oil gets bubbles and air pockets or foam. and the tolerences are so close that that could cause trouble. I use honda oil from the dealer. Hope i could help
Old Apr 4, 2006 | 12:40 AM
  #24
You shouldn't switch back to regular oil after using synthetic. syn makes seals swell just a bit and could cause a leak if you switch back and fourth.
Old Apr 4, 2006 | 02:42 AM
  #25
wood83's Avatar
ORIGINAL: ImmaSquashYou
ORIGINAL: shraz
that is a bunch of lies
you can go from synthetic to non and vice versa easily
No its not, however what you are saying is correct. Let me make this a lil bit more clear. You CAN switch from synthetic oil to non synthetic oil with no problems. Catch is, you are NOT suppose to mix ANY 2 types of oil, that is bad. You will HAVE to completely drain out ALL the oil, as much as you can to the every last drop. Hence this is why i said you are not SUPPOSE to go back and forth with the oils. Being that semi-synthetic is MORE compatible with fully synthetic, you can change the oil gradually which will prevent oil that is still in the engine to be a lil bit more giving in a sense. YOU COULD just swap the oils and shouldn't have any problems, but i wouldn't recommend it.
Old Apr 4, 2006 | 02:45 AM
  #26
wood83's Avatar
ORIGINAL: shraz
what is the difference oil is oil only thing syntthetic dose is lasts longer with out breaking down . all this you can not change back and forth is bull **** show me one case of an engine blowing up from switching???? that is crap the oil companys put out to keep you buying there expensive stuff
Old Apr 5, 2006 | 07:47 AM
  #27
rippn's Avatar
P B... 36$, schaffer semi syn, incl. wix gold filter. find out about oil yourself, by learning what additives in the different packages do... I don't care what anyone says... there IS a differences, in oil and additive packages. Boron, Phosphorus flashpoints, viscosity loss after hot, and about 20+ other measured considerations, learn ,learn, learn. then make a wise choice. Clean and free, only smoke'n harleys!!!!!!!! Ripp'n
woodypk
Feb 20, 2011 01:21 AM
tooez
The Hurricane Saloon
16
Mar 17, 2010 02:30 PM
njdjh2o
Mar 18, 2009 03:56 PM
ddcsteven
Sep 21, 2006 10:35 PM
plasteredbassist
Mar 28, 2006 04:17 PM
