97 CBR600 Wont start... PLEASE HELP!!
Hi all,
I have recently just finished rebuilding my bike, and went to start it today and it wont start.
It cranks over, but wont fire up. Bits of info that could help:
- There is no smoke coming from the exhaust when it cranks.
- Fresh battery
- Fresh plugs / air filter / oil filter
- New oil + fuel
- Carbs have been cleaned professionally
- Electronics have been professionally done
Any suggestions on what it could be?
Thanks in advance!
- Fresh battery
- New oil + fuel
Thanks in advance!
Easiest is to start with the most obvious. Contact failure in the kill switch? Are you in neutral? -> Sidestand switch jamming. Tipover switch jamming? A `97 so it`s an F3, does your fuel pump prime when you turn the key? Do you smell gas after a long crank? Have you pulled the plugs after cranking to see if they are wet?
Mattson & RoadiJeff,
thanks again, checked all them over and were fine, it was my silly error when I was plugging the solenoid back up! Got the wires mixed around lol
Just now trying to figure out why it is so lethargic when I open up the throttle - think it might be down to the air flow sensor as I have installed a Koso speedo and don't think its plugged up properly !
C Jacob W
07-29-2013 11:03 AM
mcmahan87
06-05-2013 05:13 PM
