97 CBR 600 F3 bikes dies at stop in neutral
Old Jul 25, 2024 | 07:17 PM
Draco's Avatar
Default 97 CBR 600 F3 bikes dies at stop in neutral
I got a 97 CBR 600 F3 and it shuts off when I'm in neutral and come to a stop. I keep setting the idle to 2k but it keeps going back down. Any idea? I've read maybe low oil levels can cause it to die. I just did oil and clutch I didn't fill the oil filter I just lubed the outside n threads, so maybe add like .3 more. And also low idle I set it to 2k it stay for awhilea but idle keeps going back down for some reason, I'm going to check again TM and make sure it's not me messing with it that makes it keep going too down but yeah idk. Also read fuel pump may cause idle issues and bike to die. My fuel pump is also leaking a bit anyone know how I could rebuild my fuel pump? Or link for a kit or just buy an after market one online?
Old Aug 21, 2024 | 07:08 AM
StuffAndBother's Avatar
Fuel Pump sounds fine. It's not cutting out at revs. Fuel pump only pumps when the motor is running. Bike has Carbs. It's not fuel injected
Oil change and filter is always good to do. Engine loves it and gear box loves it. Just lubing is fine. Engine will fill it for you on start for free! Just a bit less on the oil stick. I change all that every 5000km (3000 miles?)
Replace your battery. At revs the engine is making it's own voltage. At low revs your relying on the strength of the battery
Keep working with it. Heaps of you tube and I pulled workshop manuals easy of the Internet
Everything I maintain or replace makes my bike (CBR600F3 - 1998) go better. I can't say the same thing about the rider
dad0507
Jul 25, 2024 07:05 PM
Cbraider600RR
Jul 15, 2024 08:43 AM
sephrin
Dec 3, 2013 11:10 AM
michael myers
May 17, 2012 08:11 PM
rons93rr
Sep 1, 2008 09:34 AM
