rpm's at idle
Old Aug 28, 2008 | 08:59 PM
rons93rr's Avatar
Default rpm's at idle
does anyone know aprox how many rpm should my bike idle at? right now it's between 1200-1500 rpm's.
i had to change the idle to compensate for the regulator being bad and bike stalling out. i have fixed the problem and would like to make sure that the idle is where it should be.
Old Aug 28, 2008 | 09:32 PM
MI900RR's Avatar
Default RE: rpm's at idle
Clymer says 1100 +- 100 rpms, or 1200 +- 100 for California models
Old Aug 29, 2008 | 04:03 AM
DukeCBR's Avatar
Yeah, my puppy idles at 1100rpm-1200rpm. Having it at 1000rpm is too low, and she starts to "chug" a little.
Old Aug 29, 2008 | 10:44 AM
exz5string's Avatar
Iidlemine to between 1500-1800 when warmed up. I can set the idle screw lower but I think since I've got the fuel pump out & just gravity feed that's why it chugs a little below 1500,I plan on getting a new fuel cut relay and hooking all that back up soon.
Old Aug 30, 2008 | 01:19 PM
NinetySeven900RR's Avatar
My 900 idles @ 1000 rpm ... I though that was low because some times it chugs like a **** star and stalls out ... What do I need to make this problem dissappear ... I'm trying to work all the kinks out of my bike before winter arrives ... But that's what happens after you are the 2nd owner and the dude before you beat his bike up ...
Old Aug 31, 2008 | 02:33 AM
mattstunt929's Avatar
I set mine at 1,200.
Old Sep 1, 2008 | 09:34 AM
exz5string's Avatar
ORIGINAL: NinetySeven900RR
You've gotta adjust the idle screw while it's running & warmed up, turn it until it idle's up a bit
SPR-GRN
May 7, 2012 06:08 PM
prowheelie92
Aug 5, 2010 04:42 PM
acquarossa
Jun 9, 2010 07:05 AM
ThisisMickey
Feb 10, 2007 06:22 AM
BRC223
May 29, 2006 05:22 PM
