idle rpm
Old Jun 3, 2010 | 12:53 PM
acquarossa's Avatar
Default idle rpm
just picked up a nice little FJ and it idles at like 1500, is that the norm? i tried googling it but couldn't find anything. What does your FJ idle at?
Old Jun 3, 2010 | 02:03 PM
dscott16's Avatar
I have a 88 cbr600f and it idles at 1100-1200. I think I read somewhere that mine is supposed to be at 1100 +/- 100rpm at idle.
Old Jun 3, 2010 | 02:30 PM
acquarossa's Avatar
cool thanks, i thought that 1500 might be a little high. it smells rich too so i think the choke might be stuck on or needs adjustment.
Old Jun 3, 2010 | 03:57 PM
dscott16's Avatar
yeah if i leave my choke on a little it will idle a little high. there should be an adjustment **** on the left side of your bike to adjust the idle, make sure the engine is warm before you adjust it and make small adjustments at a time while reving the motor a bit between adjustments.
Old Jun 3, 2010 | 06:01 PM
acquarossa's Avatar
that **** idle adjust or choke adjust?
Old Jun 3, 2010 | 10:28 PM
dscott16's Avatar
Sorry to not get back sooner. Had to go into work for a bit. It is for the idle. Do you know if the carbs have ever been cleaned? If they have not been cleaned for a while it would be a good idea to do that. There is a good tutorial on this forum but I'm not sure where it went I'll help you find it if you would like.
David
Old Jun 4, 2010 | 11:24 PM
acquarossa's Avatar
so i found out why it idles so high. it was set that way because it bogs if the idle is any lower...looks like the carbs might be due for a cleaning
Old Jun 4, 2010 | 11:28 PM
acquarossa's Avatar
ive worked on single barrel carbs b4 so i hope its not too different. i'll look around for the tutorial but if u find it b4 me definitely post it thanks!
Old Jun 9, 2010 | 07:05 AM
dscott16's Avatar
how is your carb adventure going? Here is a tutorial on cleaning https://cbrforum.com/forum/showthrea...=carb+tutorial hope it helps if you have not already found one. I'm sure that it is not much different than the other carb work that you have done.
Good luck,
David
SPR-GRN
May 7, 2012 06:08 PM
prowheelie92
Aug 5, 2010 04:42 PM
bigboi18184
Nov 19, 2008 03:09 PM
ThisisMickey
Feb 10, 2007 06:22 AM
BRC223
May 29, 2006 05:22 PM
