idle RPM's ...
Old Nov 18, 2008 | 05:12 PM
bigboi18184's Avatar
Default idle RPM's ...
At what RPM should my bike idle at when i start it.Right now i have it adjusted to 1k rpm at idle, should it be closer to 2k ?
From what i've seen on you tube and other videos of bike started right off it sounds like their running around 2k rpm at idle, though this may be with the choke engaged.
Old Nov 18, 2008 | 05:46 PM
12Pack's Avatar
Default RE: idle RPM's ...
first off what bike do you have? second you should just check the manual. 2k is really to high for idle. Mine is set at 800-1k
Old Nov 18, 2008 | 06:26 PM
Got a 99 cbr f4 not orginal owner probably closer to 20th if i had to guess, do not have a manual. Only reason i was thinking 2k is because of the videos i've seen were people are starting their bikes and the sound of the pipe. All the ones i have seen are reving pretty high when first busted off. Under 1k my bike almost almost dies at idle.
Old Nov 18, 2008 | 07:09 PM
Hurricane rider's Avatar
idle should be roughly 1200rpm on most any motor, regardless of what it is. I think theres normally a sticker under your seat that says what to set the idle to.
Old Nov 18, 2008 | 07:12 PM
HeresJonny's Avatar
ORIGINAL: bigboi18184
yea me 2
Old Nov 18, 2008 | 07:33 PM
D2VW14_20's Avatar
1200-1500 is pretty common
Old Nov 18, 2008 | 07:35 PM
PlayfulGod's Avatar
ORIGINAL: D2VW14_20
+1
Old Nov 18, 2008 | 07:41 PM
FLYOU's Avatar
1300RPM +/- 100RPM per service manual.
Old Nov 18, 2008 | 09:53 PM
bigjohnstud4200's Avatar
ORIGINAL: FLYOU
+1
Also, are you taking about cold idle or warm idle? When you first start up cold, the bike usually idles high. If my choke is on, it usually idles at 1700, then a couple minutes later it's at 2300, then a few minutes later 3000. Once it's warm, she sits at 1400.
Old Nov 19, 2008 | 03:09 PM
ORIGINAL: FLYOU
ok downloaded manual yesterday and found it, not quite 800 to 1k rpm.
SPR-GRN
May 7, 2012 06:08 PM
prowheelie92
Aug 5, 2010 04:42 PM
acquarossa
Jun 9, 2010 07:05 AM
ThisisMickey
Feb 10, 2007 06:22 AM
BRC223
May 29, 2006 05:22 PM
