96 cbr 900 sound???
Old Feb 25, 2018 | 05:13 PM
Cbr900rz's Avatar
Default 96 cbr 900 sound???
I resynched my carbs and was just wondering if this is how my bike should sound? All comments welcome.
Old Feb 25, 2018 | 06:10 PM
EchoWars's Avatar
You hearing something I'm not? Sounds decent.
Old Feb 25, 2018 | 06:20 PM
Cbr900rz's Avatar
I was thinking that maybe the return to throttle was kinda slow. Maybe it' just me.
Old Feb 26, 2018 | 05:49 AM
EchoWars's Avatar
Does drop a tad slow.
Usual causes:
Poor carb sync
Crap gas (and even 10% ethanol may do this on finicky engines)
Lean mixture / Overall carb adjustment (slow jet clogged / idle (pilot jet) dirty or clogged / idle air mixture set too lean
Old Feb 26, 2018 | 06:32 AM
Hawkwind2016's Avatar
Other things to look at would be the throttle mechanism itself.
Are the cables routed correctly/not pinched/properly lubed.
Does the throttle mechanism snap back nice nice and sharp? If the handlebar end weight is over tightened it can snag on the grip.
Old Feb 26, 2018 | 08:36 AM
One thing that will help is to video the bike at idle and zoom in on the tach. Don't rev it. Just let it sit and idle. Show that as it reveals as much as the other.
Old Feb 26, 2018 | 06:15 PM
Cbr900rz's Avatar
Here is a video of it idling and I also have the motion pro carb sync hooked up to it. The pilot screws are set at 3 1/4 out.
Old Feb 26, 2018 | 08:31 PM
That looks good and steady, both on the tach and sync guages. Both throttle cables have good tension? With the engine off, if you manually open the butterfly valves all the way, do they snap back quickly?
Old Feb 26, 2018 | 09:41 PM
Cbr900rz's Avatar
I bought new throttle cables and installed the pull cable. But couldn' get the push cable installed. I tried putting it on the throttle pulley housing first then putting it on the carburetor throttle cam. And tried the other way around. It's seems like it's not long enough. Is there something I'm missing? And I have the right one I compared the old one next to it. Idk. But it still seems to snap back without it. But I would like to get the push cable installed.
Old Feb 27, 2018 | 05:29 AM
EchoWars's Avatar
You need that cable on brother. Partly for safety, and partly for proper throttle response.
