96 cbr 900 sound???
Does drop a tad slow.
Usual causes:
Poor carb sync
Crap gas (and even 10% ethanol may do this on finicky engines)
Lean mixture / Overall carb adjustment (slow jet clogged / idle (pilot jet) dirty or clogged / idle air mixture set too lean
Usual causes:
Poor carb sync
Other things to look at would be the throttle mechanism itself.
Are the cables routed correctly/not pinched/properly lubed.
Does the throttle mechanism snap back nice nice and sharp? If the handlebar end weight is over tightened it can snag on the grip.
That looks good and steady, both on the tach and sync guages. Both throttle cables have good tension? With the engine off, if you manually open the butterfly valves all the way, do they snap back quickly?
I bought new throttle cables and installed the pull cable. But couldn' get the push cable installed. I tried putting it on the throttle pulley housing first then putting it on the carburetor throttle cam. And tried the other way around. It's seems like it's not long enough. Is there something I'm missing? And I have the right one I compared the old one next to it. Idk. But it still seems to snap back without it. But I would like to get the push cable installed.
