93 900rr speedometer gauge not working
Old Jun 3, 2011 | 09:09 AM
gigaman1's Avatar
Default 93 900rr speedometer gauge not working
The cable to the gauge doesn't spin, easy fix or suggestion? What is common cause?
Old Jun 3, 2011 | 01:28 PM
MadHattr059's Avatar
Probably broke in the middle, these tend to be over-looked in regular maintenance.
Pull the cable off the tire hub end and rotate tire. If the slotted end is rotating the tire hub is ok. Disconnect the other end from the speedo housing. Try turning one end of the cable and see if other end rotates. If it doesn't, you'll need to replace the cable. Not a particularly challenging task. Just be sure to note how the cable is routed up through to the guages before you remove to replace.
Ern
Old Jun 3, 2011 | 05:45 PM
gigaman1's Avatar
Thanks! Sounds easy to check
mervyn
Oct 28, 2011 04:48 PM
Rippin6Gears
F4i - Wanted
May 7, 2011 06:02 PM
SlavDog
Aug 29, 2009 06:47 PM
HAVOC
Apr 23, 2007 05:03 PM
NeonspeedRT
Mar 28, 2005 04:45 AM
