93 900 Question
I own a 93 900 RR and I was rollin down the road the other day and my bike cut in and out like i was running out of gas. I had enough momentum to roll into a gas station. Had half a tank. Bike will turn over but will not fire up like its not gettin any gas. Pulled off tank and replaced fuel filter. Tried to test fuel pump by running wires out of connector to battery to see if it would prime but got nothing at all. Is there any other way to test the pump before I go ahead and order one assuming that its the problem? Any Advice would be greatly appreciated, Thanks.
OK, tested the pump again and it came on with power straight from the battery but will not energize when connected to connector from the bike. Any fuses in the mix here or what about fuel cutoff relay. Any advice would help, except that tellin me my bike doesnt have a fuel pump and its fuel injected. Thanks.
viva_brasil
Jun 9, 2008 04:38 AM
