929 dropped need help!!!
Old 04-16-2008, 04:39 PM
superbs929rr's Avatar
Default 929 dropped need help!!!
ok here is my problem . My kick stand got put down and the damn spring that keeps it down broke. so of course it fell hard in the driveway on the stator/alternator side. So oil leaked out ect ect i was screaming . i was so pissed . i got a new stator cover put it on with a new gasket and had a oil leak . so then i looked closer and i have a hairline crack very ver small in the engine house where the cover bolts to . I am pretty shure that is all one piece and i am screwed. if anyone has any suggestions or had this happen before please help cause i am not shure what to do next . Thanks for reading !!!
Old 04-17-2008, 12:04 AM
KidCr3nshaw's Avatar
Default RE: 929 dropped need help!!!
Weld it.
As for the spring, it's only to helpbring the stand up and hold it there, not down. Was anyone around it - I guess what I'm saying is, are you sure it just, "fell over?"
Old 04-17-2008, 12:28 AM
Yeah you'll need to have your cases welded, or find a set of used cases from ebay or something. and just replace the springs, shouldn't be too much, but is the least of your worries. Sorry about the bad luck you ran into man
Old 04-17-2008, 01:12 AM
His block has a crack, he's already replaced the stator cover.
Old 04-20-2008, 09:25 PM
yea got a new cover just have a slow oil leak from the engine case now .ERRR this bike was sick to it sucks so bad
Old 04-20-2008, 09:52 PM
NY Erion929's Avatar
Try some JB weld.. If you say its just a "hairline crack" it should be fine
txf4igirl
06-14-2008 11:37 PM
bluej511
01-20-2008 10:56 AM
c0ldf1ame
04-24-2007 03:16 PM
okaw
03-13-2007 10:16 PM
02F4iSlvrRed
08-14-2006 05:58 PM
Quick Reply: 929 dropped need help!!!
