900RR starting issues
Old 03-23-2013, 05:10 PM
gunslinger1274's Avatar
Update, went ahead and had the battery tested at a better local shop. Said the battery wouldn't even take a charge for them to do a load test. Bought a new battery. Went to install it, but checked the regulator. Middle yellow plug was slightly melted on the harness. So I assume that my regulator is bad. Pic included of the wire harness. Inside the regulator, you can see it is a little melted, but nothing outrageous. I assume, that I need to replace the regulator before I do anything further, correct?
If I buy a new regulator, do I need to change out the wire harness, or would it be OK to clean up and use it still? The connector inside still looks ok, so if I clean it up some, will it be OK?
Old 03-25-2013, 04:11 PM
katt72's Avatar
it would be best to change out the harness along with the regulator. Being that the pins inside the harness are burnt. This will only prolong another issue down the road.
Old 03-25-2013, 06:32 PM
Vinman911's Avatar
Member & ROTM AUG 2013
Change the plug. eBay has them but thier in china may take a week or 2. Bikebandit may carry them.
grimreaper
03-12-2021 07:35 AM
sickCBR599
07-05-2011 03:51 PM
CMA_Like_A_Boss
06-03-2011 05:26 AM
nitrodude
F2 Tech
19
05-21-2010 10:18 AM
BRC223
04-13-2006 10:42 PM
Quick Reply: 900RR starting issues
